2005 300 Will crank but no fire?
Discussion in 'Chrysler 300 General Discussion' started by Laker 5, Nov 27, 2017.
  1. Laker 5
    Laker 5 New Member
    Nov 27, 2017
    2
    0
    Gender:
    Male
    Lucknow
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2005
    Trim?:
    300
    Color?:
    Brilliant Black
    Help My car started this morning then chugged out. I added some fuel and it sounds like the fuel pump is coming on. is there a fuel reset or any way it could be frozen up? It was-2 last night and the car will run fine if you put fuel in the intake hose? Thanks for any replies gang
  2. Ccornwell
    Ccornwell New Member
    Jan 6, 2018
    2
    0
    Gender:
    Male
    New York
    Vehicle:
    300 Limited
    Vehicle Yr:
    Gen1 - 2005
    Trim?:
    Limited
    Color?:
    Midnight Blue
    Sounds like a fuel delivery problem if you aren't getting it to run without pouring fuel down the intake. How much fuel did you add to the tank? Did to attempt to prime the fuel pump by turning the key from acc to on waiting five seconds then repeating several times? I have found in my experience of running vehicles out of fuel that usually 5 gallons will get it started but it sometimes is hard for the fuel pump to push. Also, did you add new fuel or something you had laying around?
Share This Page
