This is my first time asking but I've had quite a few of my issues answered here.A couple days ago my 06 3.5 started running rough af. It gave a code of intake air temp sensor, changed that but no change. The new code was post catalyst bank 1 too rich. Changed the o2 sensor but no change. No exhaust leaks i can find and I changed plugs and coils a few months ago. It's not giving any codes now but still misfires. Any ideas?
What exactly are you using to scan for codes?
I have 2 code scanners, a cheap Walmart one, very basic and a better one I ordered. They both give the same result. I found a vacuum leak at the egr tube and fixed that and did a resistance test on all the coils and found no bad ones. I'm going to replace the spark plugs too. I'm now getting a code for slow response bank one and o2 sensor 2 bank 1 and another for the intake air temp sensor.
If you have access to an advanced scantool that can read Powertrain, Chassis, Network and Pending codes, I would definitely try that. AlfaOBD or DiagFCA with a cheap Bluetooth OBD device works really well on our cars.
Have you Checked all your connections as well as the EGR. the mechanic damaged the seal and my 2.7 ran rough cause they damaged the inlet. I duct taped it and no rough idle and car is silent
