2008 300 window issue(switch not working properly)
Discussion in 'Troubleshooting' started by slayerextreme, Mar 7, 2016.
  1. slayerextreme
    slayerextreme New Member
    Mar 7, 2016
    1
    0
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2008
    Trim?:
    Touring
    Color?:
    Cool Vanilla
    let me start with ...this was a self induced issue. My wife knocked the drivers side mirror off, so I ordered a new one...I had a horrible time getting the drivers side door panel off, and I'm sure I have damaged the window wiring when I replaced the mirror...with that said, I have tried to find a window electrical schematic and can not locate one...now on to the symptoms.
    LF window does NOT operate normally from drivers switch
    RF window does NOT operate normally from drivers switch
    RF window operates normally from its switch
    LR window operates normally from its switch
    RR window operates normally from its switch
    LR window operates normally from drivers switch
    RR window operates normally from drivers switch
    every now and then the drivers side front window will work using the driver side switch, but the passenger side window will never work from the drivers side switch.
    I have taken the door panel off and inspected to the best of my ability the wiring for the 2 window plugs on the drivers side switch, no visible damage.
    I replaced the entire drivers side window switch cluster today and the fault still remains ( I was hoping I might have shorted something during my initial door removal)
    so I am now trying to locate what wires are common to the LF and RF windows from the drivers side window switch cluster and I believe I will need a schematic...
    any help or advise would be greatly appreciated
  2. Conky
    Conky New Member
    Jul 21, 2017
    9
    0
    Gender:
    Male
    Winnipeg, MB. Canada
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2010
    Trim?:
    Limited
    Color?:
    Mineral Grey
    Hello
    I have exact same problem with switch
    tried a new one but has same issues
    Need a complete wiring diagram for door switch I think
    I would be very surprised if the door wire had broken after only 7 years 130k
  3. Conky
    Conky New Member
    Jul 21, 2017
    9
    0
    Gender:
    Male
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2010
    Trim?:
    Limited
    Color?:
    Mineral Grey
  4. Conky
    Conky New Member
    Jul 21, 2017
    9
    0
    Gender:
    Male
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2010
    Trim?:
    Limited
    Color?:
    Mineral Grey
    Fixed it myself
    Pulled fuse for windows and it reset window controller
    now it all works just from pulling and reinstalling # 10 fuse in trunk
Share This Page
