Hi, gonna put some stuff here to help me remember when i try to find custom wheels i wanna buy for the "Cookie Monster"..... Haaa
Tire sizes car could have come with
Stock Wheel Size: 18” x 7.5”
Stock Tire Size: P225/60R18 widest i can go 255/55R18
Stock Wheel Size: 17” x 7” Wheels stock offset = 15mm
Stock Tire Size: P215/65R17 widest i can go 235/60R17
For size comparison Rock Auto sells a wheel for 2009 300 2.7L with
18 X 7.5
bolt 5 X 115
offset 16mm
backspacing 125mm = 4.92"
Offset measures the distance between the wheel’s mounting surface and centerline
Backspacing measures the distance between the wheel’s mounting surface and innermost lip
steps
1. rim diameter big enough to not hit the calipers, etc....
2. rim width not too big it hits car when turning
3. bolt pattern must allow wheel to fit on car
4. offset must not allow wheel to hit car body parts
5. backspacing must not allow wheel to hit suspension parts
Wheel i like and found on tirerack.com
i picked 17 X 7 with 5X115 and offset 6 in GunMetal with Machined Lip
Will these bolt on my car with no issues?
I need to figure out the math to understand why my stock wheel with 15mm offset and the wheel i picked with 6mm offset both fit the car fine, according to the discounttire site ??
Thanks.
Tirerack had pick with 20X8.5
-ALF
18 X 7.5
bolt 5 X 115
offset 16mm
steps
- Size:18x8
- Offset:20mm
- Backspacing:5.28" = 134mm
- Bolt Pattern:5X115mm
- Rec. Tire Size:225/60-18
Thanks.
-ALF
