Hi guys. Have a 2007 300, 5.7 that dropped a valve seat and destroyed cylinder wall. Found a deal on a 2018 wrecked Charger with low miles. Any chance engine will work? I know VVT is different but what about Engine accessory brackets, sensor wiring etc? Would plan on using 2007 Trans unless 2018 would work. 6.1 is also an option.
Any help greatly appreciated.
The Eagle won't drop in and you can't use the Eagle block with your heads and accessories. About the only option you would have would be to take the Eagle whole, including all the electronics, and swap it over, but unless you're getting skilled labor for free, that's just not going to be practical.
