OK so firstly I'd like to say hi to everyone as completely new here, so "ello" and then to the questions.
I have bought a set of these wheels above and am quite worried that there not going to fit. I'm going to need spacers on them as there 5x114.3 and my 2010 supports 5x115 so with spacers on I'm concerned there going to stick out to far etc. Anyone have any ideas or opinions on this? Are there any places that do wider arches for the 300?
Also struggling to find spacer adapters from 5x115 to 5x114.3 as the wheel bore size is 76.1!
Thanks in advance everyone.
Hi For reference I use this site 5 X 115 Bolt Pattern Cross Reference and Wheel Sizes ~ Roadkill Customs
Then I found this on amazon following the links,
The bore is smaller, but I'm sure one is in there. Maybe they could be modify by a metal work shop.
Those links, specifically the second are pure gold. Thank you for sending me that. The wheel offset is 30, do you think it would be better for to get the wheels rebored to the correct size, due to width? I don't want them sticking out further than arches as to many bumps where I live. Arches will be destroyed ?
The 17 Inch wheel have 22mm offset and the SRT Wheel have 24 mm, So you are looking at maybe 1/4 inch more out side for the offset. You will need to add the spacer dimension. IDK about changing the bore size on the wheel. But the Car hub is 71.5mm, so it's smaller. You will need to fill the gap if you can't find a spacer that fit the dimension, if not you risk the wheel moving a little has they rotate and make horror sound going down the road !
The amazon link if you click on the company, has a nice page and plenty more addaptor, Other option if the bore size don't fit, StanceMagic: Jeep, Dodge, & Chrysler
If you can contact one of these company maybe you can have one made to your need. Or they might have more on there own web site.
