1 - 9 of 9 Posts
Not enough information to compute.
What do you drive? What transmission have you got? How long have you owned it? Has it ever had a performance tune applied? Has the trans ever been serviced? Have you checked the fluid level? Does it do this consistently, or only once? What happens if you clear the code? Are there any other symptoms, like slipping in 3rd gear?
2007 Chrysler 300. Fluid change and filter changed 2 weeks ago. I had my transmission replaced back in 2018 because I had this same problem. 2 years later it’s happening again with the same code? Once I drive over 20 miles my car starts to stall out so I have to shut it off start it back up and get it to accelerate again. No tune up
Yes it slips in 3rd gear and I did clear the code but I didn’t drive it long enough for it to come back on because I don’t want to risk getting stuck on the side of the rode
I still don't know what transmission you have, so I'll just say that if you don't have a dipstick to check the fluid level yourself, take it to a trustworthy local shop and have them do it.
Okay, so you have a NAG1. They're sensitive to fluid level. Take it to a shop you trust and have them check the fluid level using the factory-approved procedure.
Hi I have a 2006 Chrysler300c First it would stall when I filled the gas tank. Chrysler replaced the gas tank. Now it's worse. The car dies at stop lights, dies when I'm driving down the road. I've taken it to the dealer and they told me to replace the computer which didn't help. I've taken the car to some good mechanic's and they can't figure out what the problem is either. I also called Chrysler and they don't want to do anything to help. My e-mail is [email protected] and I'm going to start a class action lawsuit. If anyone that has a 2006 or 2007 having the same problem. Send me your e-mail and just say engine stalls while driving so I can give your e-mail to the lawyer to get hold of you. I think it would look better if the lawyer had a bunch of people to file with.
Not for anything, but you're piggybacking your off-topic post onto another, older off-topic post. You might want to start a fresh thread in either General Discussion or Help Zone.
1 - 9 of 9 Posts
