I have a 2018 Chrysler 300S (the S trim). The front brake calipers are single-piston type.
The other day I was driving my son's 2018 Dodge Charger SXT Plus, I noticed that the brakes are much better than my 300S. I looked at the Charger's brake calipers, they are double-pistons (or two-pistons).
I am thinking about changing my 300S brake calipers from single-piston to double-pistons. Will that work? I understand that PowerStop sells double-pistons brake calipers for Chrysler 300. Check that out: Performance Brake Calipers | PowerStop | Powder Coated Pair
Just in case if you don't know how to identify your brake calipers... if you see "one arch" on the brake caliper, that means you have a single piston. Two-arches = double-pistons.
thanks -madmax
thanks -madmax
