My car makes a clunk noise each time we go over a small pot hole or bump, replace some warn out tie rods, control arms, wheel bearing, I need some new tires but not that drastic also alignment. Any advice would much thank.
It could be a bunch of different things. In my case, I found that the sway bar end links were primarily to blame. They're cheap and not hard to replace...might as well do the sway bar bushings at teh same time. After replacing those, the noise subsided substantially, but not completely. I then found that the nut on the top of one of the struts (under the hood) was loose...I tightened it, and now the front end is tight and silent.
