GUYS,
im running high temps, even though i installed the "JET" BRAND 180 DEGREE THERMOSTAT...
I got a predator tuner but i'm not hooking it up to my car anymore (bad pcm experience, wound up buying a refurbed one ).
SO...... is there another way to trick or alter the fan-temp senser to read higher to activate fans ????
hi, how old is the liquid,
The sensor is probably base on voltage or amp, depending on a certain value it will trigger a binary switch and/or a relay. You could always add a resistance to modify the voltage/amp.
For that you would need the electric diagram to determine the values.
A second option I can think, you could manually bypass the sensor whit a switch you could start yourself.
Thank you for that... I like first idea and second ideas..... Not sure how to calculate resistor to increase 20 degrees more...
+1 for toggle switch and adjustable fan thermostat to engage fan.
This way, theres no risk of killing your battery by leaving the switch "on".
I'm electrically skilled, can someone direct me to a "fan thermostat" ???....
Not familiar with these.
I haven't done electrical math in a while also, my lazy solution would be to use a variable resistance, so that you can actually adjust it any time you want.
sound like a good idea but I wont say it could not have bad effect on the original circuit. Add a fuse in there for safety :3
