I be been having some issues with the egr mainly the dreaded p1404 But occasionally the p0404 Well at least after the new egr install. When the 1404 shows itself it’s usually followed by a stall or a bucking for a half mile ive worked the problem going thru the wiring to valve nothing obvious I did purchase the AlfaOBD KEEP IN MIND THAT WAS TO TURN OFF THR TPM That worked well
Problem is I haven’t been able to get it to do much more If I delete the egr valve I’ll also need to turn it off in the pcm Not sure how to do that Has anybody done that ?
was looking the code up to see what it means,
Sound like a few option here. I don't think you should remove the egr valve. Replace it maybe or clean it.
