FS: Chrysler 300 "HALO" Angel Eye Kit! Single and Multicolor Options!
Discussion in 'Diode Dynamics' started by Diode Dynamics, Jan 27, 2014.
  1. Diode Dynamics
    Diode Dynamics 300 Lighting Experts Platinum Vendor
    Jan 22, 2014
    133
    1
    St. Louis, MO
    Vehicle:
    300C
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    300C
    Color?:
    Brilliant Black
    [​IMG]
    Chrysler 300 Angel Eye Kit
    SMD Ring Angel Eyes can be installed on any vehicle as an accent for your headlights. They can be found on BMWs and are a nice modification for any vehicle. Diode Dynamics' angel eyes are the highest quality and brightness available. We encourage you to shop around, you will not find better angel eyes for these prices! Our rings were custom-designed for reliability and long life, and have been tested on your vehicle for perfect fitment.
    Our multicolor rings use SMD technology, a modern type of LED that provides a bright forward-firing light, creating a circle of light inside the headlights.
    Our newest product, RGB MULTICOLOR angel eyes come with a remote control, in order to pick the color or effect you want. The controller has a static memory, so you can leave the angel eyes switched to WHITE for every time you start your car and drive around, then get out and change up the color! They also come with a custom wiring harness, for plug-and-play wiring, and a standard RGB controller unit with remote. We also offer a WIFI controller option which allows you to control them via smartphone app.
    Kit includes:
    • Four (4) Multicolor RGB SMD Rings, fitted for your vehicle
    • RF 28-Key multicolor remote, to change the color OR Upgrade to Wifi controller
    • Diode Dynamics Plug-and-Play Wiring Harness
    • Installation guide
    • Three year limited warranty
    We use custom-manufactured SMD rings through our top LED manufacturer, with high-grade AAA resistors and LED chips. They are highly durable, with a black backing color. The LEDs go all the way around the ring, for no "break" in the light as with other angel eye designs, and are ten times brighter than old fiber-optic type rings.
    Installation requires you to open the headlight, by using heat from either your oven or a heat gun. It sounds bad, but really isn't too hard. Simply remove all screws, heat the seal, and pull apart. We have installation videos and other helpful guides available at diodedynamics.com/install. The wiring is a plug-and-play installation, using our Diode Dynamics Angel Eye Harness and quick disconnects. You will not have to do any soldering, wire stripping, crimping or anything. Our wiring harness makes wiring a breeze!
    Don't want to do it yourself? Looking for a kit for a different model? We can do any vehicle for you, with our large inventory of ring sizes. Contact us for information.
    All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
    Chrysler 300 Angel Eyes
    [​IMG]
    If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
    Thanks for looking!
    *PM us for the free-shipping code* (U.S. forum members only)
    Nick C.
    Diode Dynamics
  2. LeeSoFL
    LeeSoFL New Member
    Sep 12, 2007
    27
    0
    Wellington, FL
    Vehicle:
    2013 Varvatos Luxury
    Vehicle Yr:
    Gen2 - 2013
    Trim?:
    300C
    Color?:
    Brilliant Black
    Don't want to be a pooper, but are red and blue lights street-legal?
  3. Diode Dynamics
    Jan 22, 2014
    133
    1
    St. Louis, MO
    Vehicle:
    300C
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    300C
    Color?:
    Brilliant Black
    With the RGB Multicolor options you can leave them on white for road use
    Red and Blue are not recommended for on-road use and will not be road-legal
    Nick C.
  4. Diode Dynamics
    Jan 22, 2014
    133
    1
    St. Louis, MO
    Vehicle:
    300C
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    300C
    Color?:
    Brilliant Black
  5. Diode Dynamics
    Jan 22, 2014
    133
    1
    St. Louis, MO
    Vehicle:
    300C
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    300C
    Color?:
    Brilliant Black
    [​IMG]
    [​IMG]
    Replaced the dull CCFL halos with our HDHalo switchbacks! Dezert Lighting
  6. Big Daddy
    Big Daddy Active Member
    Feb 14, 2009
    1,173
    51
    New York
    Vehicle:
    300
    Trim?:
    300C
    Color?:
    Dark Lava Red
    I checked your website and it's not showing an angel eye kit for a 2005 300C.
  7. Diode Dynamics
    Jan 22, 2014
    133
    1
    St. Louis, MO
    Vehicle:
    300C
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    300C
    Color?:
    Brilliant Black
    We don't have a vehicle-specific listing for the 300C, but we have universal sizes that will fit. Keep an eye on the site and the forum for updates. I will post more information when we have updates.
    Thanks!
    Nick C.
Share This Page
