i just added a Brute force CAI and love it! There is a PCM performance module that is sold by JET. The specs are below. Has anyone heard of this, as a friend said good things about it for just wanting stage 1 improvement??....
Features
  • The Jet Performance Chips Power Control Module is custom-made and programmed for your vehicle
  • Blow stock settings away off the line-The Jet Chips PCM tunes your engine with more advanced programming to harness your vehicle's full power
  • The Jet PCM greatly boosts horsepower—see related images to find out how much it can help your vehicle
  • Get faster acceleration, better 0 to 60 times, and boosted towing power without burning extra gas
  • The Jet Performance PCM is available in 2 stage models for most vehicles:
  • Stage 1: This Power Control Module (PCM) is designed for stock engines with no other modifications. The Jet Stage 1 PCM is programmed to maximize power increases based on stock parameters
  • Stage 2: This Power Control Module (PCM) is designed for modified vehicles with low restriction exhaust and low temperature thermostats. Unit takes advantage of these modifications and pushes your engine for maximum power
  • The Jet Performance Module Chip offers quick, easy installation in less than half an hour with no warranty-voiding seal breaking or other modifications
  • To return to your factory settings, just unplug the Jet Performance Module
  • Won't void your warranty-the Jet Chips PCM has been thoroughly tested not to damage your engine components
  • The Jet Chips Power Control Module is legal in all 50 states
  • Your Jet Performance Power Control Module is backed by a Lifetime Warranty
Description
Unleash the high-performance potential of your engine and say adios to sluggish factory settings in less than half an hour with the Jet Performance Power Control Module. Jet's Dynamic Spectrum Tuning (DST) optimizes air/fuel ratio, spark timing, transmission tuning and various other parameters for maximum horsepower and torque.
Jet offers their Power Control Module (PCM) in two styles for most vehicles: Stage 1, for original stock engines; and Stage 2, for the modified motor with performance air intakes, headers or exhaust systems already installed. Even on souped-up engines, The Jet PCM adds serious horsepower to your driving (see Related Images for vehicle-specific gains).
Jet's expert engineers use their decades of fine motor tuning to help you discover what hidden power lies beneath your vehicle's hood. Your Jet Performance Chips PCM is legal for cruisin' in all 50 states and boasts a Lifetime Warranty.
I love this site...as you guys are awesome for sharing. I dont plan to change out exaust, or anything much more than the 180 degree temp sensor and the CAI I just did....doesnt the predator take doing a dyno and making alot of programming and changes?......?
Jet chip is a waste of money. You will not notice any difference, nor has anyone seen measurable gains from one.
If you do want gains, look at the Diablo Predator. www.diablosport.com
Nope....they have a pre installed tune that is perfect for what you are doing. Simply plug it in...maybe do a couple of updates and you are done. You'll definately get at least 12-15hp out of it, and make real gains out of that CAI that you have.
If you ever decide later on to go wild with cam/heads, etc then there isn't any replacement...just some new tuning needed on a dyno.
