So, here's my 2010 limited and I love it. Yep, it has 275K miles on it but she's clean and pretty. Just picked her up in Florida on February 8th. Unfortunately, the joy ended two weeks later. I got the lightning bolt. No engine codes. So, after the research, I changed to a new Throttle body, well, that did not make any difference, So, I said, must be miscommunication between throttle body and pedal because the car idles great around 600 and I put me a new pedal in, again, no change, lightning bolt still on, no engine codes. I decided to change out the computer, what else could it be ?? Then I found that a squirel or rat has been eating on the connector wires, the black/yellow wire is completely severed and some other wires are damaged. So, very possible that the old throttle body and the old pedal are perfectly fine. Now, my question is, what is the black/yellow wire for, first connector on the left. I added some pictures for your enjoy and amusement.
So, we fixed the wires, no more lightning bolt, no engine codes and she is running as smooth as she was before. So, I can basically assume that a bought a new throttle body and a new pedal for nothing. I decided that maybe i can help somebody else with these parts. I will sell the pedal and the throttle body for $50.00 each + shipping. Pictures below, just shoot me a message if you are interested but understand that I can not warranty these things. They worked fine before the rodent ate my wire harness so they should
be fine now.
be fine now.
