Here's the rub, I have a 05 300c car has low rpm hesitation and does unless I nail it on highway then it runs just fine. No lightning bolt or eas/ bas lights or codes except for the 2 downstream 02 sensors which haven't caused any issues whatsoever for the last few months, everything started after I cleaned throttle body. Loss of tps signal on evic every so often now and it clears right up after I pull #11 fuse and recalibrate. Runs great until I shut off or force my electric fans to come on with AC. I just did a AC clutch rebuild, and put a new throttle body in, new radiator and coolant sensor switch and still have issues with fans not coming on unless I bypass them or start AC. All along now the hesitation and rough idle until I reset with the fuse. Already had tuneup and wires, plugs, etc and intake gaskets done
