I have 2006 300c AWD. I am having transmission problems. The car shifts fine til it hits 3rd gear. Then it gets stuck in 3rd gear til I shut the car off and open the door then fire it back up. I am pulling codes u0101, p0700, p0731, p0733. I have checked all fuses and relays. I replaced the tcm and got it flashed to my car. Replaced the conductor plate, transmission harness connector, transmission fluid, and filter. Seems like nothing has worked. Have also tried resetting the transmiison by pulling the corresponding fuses. If anyone has had this problem or knows this fix it would be much appreciated for the help. TIA
