Hi, I have search the codes on googles and Database can't find the extended one for the description. I am assuming it is a location code maybe.
So I have P0159, P0157 and "P0159 Pd", I have a good idea what the problem is, Still I am curious about the Pd code ?
Has any one seen this before. I'm using an "AutoLink AL301" To read the codes, 300 touring 3.5L 2010.
Discussion Starter · #2 ·
Well did some more research today and found the PD in the User manual, it stand for "Pending". So a little more google and I found the explanation if any one interested.
Pending codes (also known as continuous monitor codes) will be registered when an intermittent fault occurs. If that fault does not happen again after x number of start/stop cycles, the ECU will erase the code from memory. If the fault is persistent it becomes a DTC.
