2006 300c 5000 mikes since complete overhaul, mds eliminator kit, melling oil pump
other then that its stock.
started getting codes indicating oil pressure problems. on startup 90lbs after warm up 15 lbs
I replaced sensor behind the alternator. cleared codes, change oil 5w20 synthetic
on startup 50 lbs driving down road 50 lbs. come to a stop when warmed up it idles at 600 rpm with 15 lbs
when you take of it climbs up to 50 lbs and stays there until you stop. question is is that gonna be a problem? anybody experience that?
thanks Guys
Keith M
