p0016 help
Discussion in 'Chrysler 300 General Discussion' started by DavidO, Dec 22, 2017.
  1. DavidO
    DavidO New Member
    Nov 6, 2009
    2
    0
    Vehicle:
    300
    Trim?:
    300
    Color?:
    Linen Gold
    My 2006 300 3.5L V6 is giving me the p0016 code. I have reset the code but it keeps coming back. In the morning when I first start the car aftter resetting the code I can drive for about 10 minutes or 5 miles with no code but then it pops back up and if I reset it comes back immediately. The car actually runs pretty good. No missing back-firing, or hesitation none of the symptoms that are accompanied by crankshaft position sensor or camshaft position sensor. Any ideas that might cause this code to throw. I don't wanna start buying parts that I don't need....Thanks
  2. jkelly16
    jkelly16 Aww Peg! Administrator Moderator
    Sep 18, 2011
    141
    32
    Gender:
    Male
    Clayton, NC
    Vehicle:
    Challenger
    Vehicle Yr:
    Gen1 - 2009
    Color?:
    Custom
  3. CTselios06
    CTselios06 New Member
    Feb 10, 2018
    5
    0
    Gender:
    Male
    Napoleon, MI
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    AWD 300C
    Color?:
    Satin Jade
    Get to a better scanner (snapon modis) and run a cam crank relearn. If it won't take a relearn you need to start by changing the cam sensor. They have mild likelihood of going bad. Check the crank sensor for metal dust that will stick to the magnet and throw off your readings
  4. weldon
    weldon New Member
    Feb 12, 2018
    9
    1
    Gender:
    Male
    GA
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2007
    Trim?:
    300C
    Color?:
    Brilliant Black
    I would definitely replace the timing belt if haven't in a long time.
Share This Page
