1 - 13 of 13 Posts
Hello all. I have a 06 Chrysler 300C that recently would stall within 30-45 seconds after starting. It runs fine and then It would just drop off like the key was turned off. It does not do this every time I start it. The first few times that It happened, just restarted and had no other notable problems. Then after starting it one time it locked on the engine light, and upon pulling the code with my code reader it showed the P0700 (which I know is just a mil request) and it pointed to the TCM, which had the code U0100. This being U0100 - Lost Communication With Engine Control Module, with these listed as the only possible causes.
Possible causes
- Faulty Engine Control Module (ECM)
- ECM harness is open or shorted
- ECM circuit poor electrical connection
I realize that there are some on here that say a low trans level can cause this as well as spark plugs. Anyway, Based on what I've read hear and other places, it seams that 99% of the time it ends up being the PCM. which is covered under the 8-80000 fed wty as I understand. And I've read that the TCM should store a code, and can store a history of the last 5 episodes. A note here I want to say that every time that the car has stalled, it does not always show the P0700 DTC, but always showed the TCM's code U0100. So based on this info, I take the car to the dealer just after the car stall, I pull the code up on my reader, and there's the U0100, so I figure good they will see this and we are on our way to getting the car repaired. I get to the dealer they check the car and tell me no codes. I show them my reader with the U0100 on it and they tell me no code, nothing can be done. OK, so off I go with no codes. ?? Where did they go? Anyway a week later ( I don't drive the car every day) I start her up and -stall. no p code but there's that U0100 on the TCM. Humm? off to the dealer . I leave it for diag. and later in the day they tell me no stall no codes. Again where would they go? I've read that the damn thing should take about 40 key cycles to clear, not dump the TCM ? Anyway the dealer keeps the car and try to see it code or stall. It stalls for them, but hey no codes?? So now Corp is called in and the dealer now under Corp's direction, have flashed the PCM, and changed all of the plugs and replaced all of the coils. Now we are waiting to see if it stalls again. today they called and said that the car has not stalled,( didn't stall every time anyway, dealer had car for three days before it did it for them) and will follow up with me tomorrow.
Thoughts guys and girls? I'm baffled at the fact they see nothing in the tcm, but my reader does. Thanks Rock
:kap:
I'm really disgusted that this has started happening to me as of today. Just after having the Fuel tank problem. So now I have to drive my car on half tank of fuel max and I have PCM engine troubles as a by product. [email protected]#$% Same 2006 300c.
What's a new PCM going to run? I am at 83K.
Before I spend $300 on a new PCM, I'm waiting for the dealership to replace my faulty Fuel tank. There is no point in speculating that my PCM is bad, since I know the fuel tank stalling can be causing additional DTC's.
By the way, my car threw out the same DTC's as yours, it only does it intermittently however and my DTC always resets after I shut off the engine. If this were actually a true fault, the codes would not be intermittently happening I believe.
same 06 300c
ok...p0100 means that there was a loss of comunication with the ecm, this is pointing at the engine control module to be at fault. if you can get it to stall consistantly then try this. remove the plastic cover that is over the pcm in the engine bay and remove both electrical connectors, the plug back in. if it wont stall or takes some time to stall again then it is the pcm at fault. a used one can be instaled but has to be programed first or it wont start, i have been threw this issue a few times and found this to be the best test, as tapping on it or wiggling wires has no affect on the issue. siemans make the control modules for chrysler and they suck. i have had 100% success with this tip. it took a very long time and a lot of money was spent sorting this out.
Same exact problem hear also new PCM should be hear today or tomorrow. it got pretty bad stalling this morrning so ill unplug and plug back in the connectors to buy me some time until the new ones in. Sucks but what do ya do,,, im glad you guys figured it out. i replaced everything but the PCM haha
Just an Update. The PCM fixed all the problems. i did get a new tank as the dealer thought this was the problem also but stalled shortly after the new tank. PCM was 300 for a refurbished one. i replaced alot of parts unnecessarily but at least I have some new parts. haha
Where did you get a used one? Any recommendations on aftermarket ones?
Hey, I have a 2006 Chrysler 300 3.5L, same problems with pcm. Lost communications but no codes are coming up. Everything works except it shuts off for no reason I can see. It stops while driving, at a red light or wont start at all.......Question, do I change out the ecm or wires or both?
I'm having the same problem.... its WAY worse when it is hot outside
same issue.. tech found bad ground under the hood somwhere.. cost 140 for me
do you have any idea where the bad ground was?
where did you get your PCM from?
Well I have an update... I went threw all my connections on my engine and found a bad ground connection on this driver side rear of engine just behind the fuel rail... it was bad so I cleaned it up and all is great now! That connection happens to be the ground for the fuel injectors FYI.
Occam's Razor....:)
1 - 13 of 13 Posts
