Please help!!! Major electrical malfunction
Discussion in 'Chrysler 300 Electrical Problems and Questions' started by Lewis, Aug 10, 2017.
  1. Lewis
    Lewis New Member
    Aug 10, 2017
    3
    0
    Gender:
    Male
    Wi
    Vehicle:
    Chrysler 300c awd 5.7l
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    AWD 300C
    Color?:
    Brilliant Black
    Where do I start!? Okay so I just bought a 06 Chrysler 300c 5.7l hemi with 80k miles. It's been running great for the first week then last night i run inside the gas station for 2 mins and when I got into my car it was shaking bad and the radio wouldn't work. I killed the engine right away. Tried to start it up and nothing so I placed a battery pack on the battery and it started right up. Radio worked again also. A mile down the road my radio,speedo and front windows stop working. Car ended up dying on my 3 miles away. I got a ride to autozone and got a alternator and replaced it quick. It started right up and seemed fine. Started driving away and I noticed my blinkers,wipers,power steering wheel tilt, cruise and front windows wouldn't work also the transmission seems to only work in 1st gear! I can't go over 35mph. Autozone tested the car and said the only code that shows up is my (abs) but has no idea why the steering wheel column isn't working. Any help would be greatly appreciated!!! I'm thinking it's some kind of electrical problem.
  2. jkelly16
    jkelly16 Aww Peg! Administrator Moderator
    Sep 18, 2011
    141
    32
    Gender:
    Male
    Clayton, NC
    Vehicle:
    Challenger
    Vehicle Yr:
    Gen1 - 2009
    Color?:
    Custom
    Test the battery if it was not already done. Even a slightly low voltage can cause issues.
    Lewis likes this.
  3. Lewis
    Lewis New Member
    Aug 10, 2017
    3
    0
    Gender:
    Male
    Wi
    Vehicle:
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    AWD 300C
    Color?:
    Brilliant Black
    autozone tested it for me and said it's 100% but I'm thinking I'll just buy a battery and see what happens. Thanks a lot!
  4. Lewis
    Lewis New Member
    Aug 10, 2017
    3
    0
    Gender:
    Male
    Wi
    Vehicle:
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    AWD 300C
    Color?:
    Brilliant Black
    I put a new battery in hoping it would fix the issue but it didn't... I'm thinking it has to be the ecu. I idea what else would cause this
  5. Valenzuelapalacio69@gmail
    Valenzuelapalacio69@gmail New Member
    Oct 13, 2017
    4
    0
    Gender:
    Male
    Mesa,az
    Vehicle:
    Chrysler 300 touring
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    AWD Touring
    Color?:
    Linen Gold
  6. Valenzuelapalacio69@gmail
    Oct 13, 2017
    4
    0
    Gender:
    Male
    Mesa,az
    Vehicle:
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    AWD Touring
    Color?:
    Linen Gold
    Thoattolbody problem cause by PCM that most likely is a short try remuve heated mirrors fuse on the trunk fuse box first, Exchange throttle body censor, pcm shorted sending bad signal to throttlenody, if u look for a short, look over the valve cover on passanger side on the top left corner there is a wires join that make a Y check the wires under where the join rest on valve cover retape wires if exposed on dont forget to get a new pcm
  7. Devon
    Devon New Member
    Yesterday
    4
    0
    Gender:
    Male
    Augusta, ga
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2006
    Trim?:
    Touring
    Color?:
    Bright Silver
    I'd say it's most likely a short somewhere. Shorts will make your car do weird things... I'm pretty confident that's what it is...
Share This Page
