I'm trying to install a dual double din in my 2005 300 i have the harness adapter wired correctly but my radio gets no power. Does it have a stock amp I'm missing?
The problem most likely isn't the amp. If you use a generic "Chrysler" harness adapter, you may find there's no ACC hot lead.
You can either manually run 12v to the ACC on the radio, or buy an LX-specific harness, like the PAC RP4-CH11 or equivalent.
I checked and the car doesn't have a factory amp by the column any other location it can be?
