1 - 20 of 24 Posts
As some of you may know, I just recently detailed my car upon storing it. Something has been bugging me for a while though. I have bugs on or in the paint. Most people that I try to show this to say not to worry about it, or they don't see it at all. The rest of the car looks great, I just have a few bugs that I want to take off. Does anyone have advice on a light compound or something a little abrasive to work on those area's? Your comments are greatly appreciated! Thank you!:smileup:
You mean you actually have bugs with wings in your paint!?:4-dontknow:
I would clay the **** out of them!
LOL! Just the splatters of them. I clayed the whole car, and paid special attention to the front bumber that takes alot of hits from bugs.
I was wondering if there is a compound that I can use that might help.
If they are on the paint wet a bounty and or dryer sheet and use it to get them off.
I read this when a friend had bugs all over the front of the car...Haven't tried it but easier on paint than compound
WOW! I've never heard that before! I will try that before I get into anything to abrasive:smileup:
I read it in one of those books that tell what other uses things are good for ...like all the stuff WD40 will do etc..
I see those books advertised all the time. Gotta get me one of those!
Discussion Starter #9
Hope that works, if not hand rub some Meguires fine cut cleaner. Should take them off without being tough on the paint.
Thank you Brad! I am going to write that down as well. I am pretty confident with the Meguire brand, but have yet to try that one out.:smileup:
I've been using some Rainex Bug and Tar remover and then a special sponge that has a netting over it to scrub the bugs. Its been working for me and not hurting the paint.
Discussion Starter #11
I've seen that stuff before. Rainex is another good product. That special sponge and the Bug and Tar Remover might be just what I need:smileup: .. Thanks for the advice man!
the bug and tar remover is paint friendly and rubbing and polishing compounds are not.
Use the remover and the dryer sheet first. Then use a paint cleaner, clay the area again, if you're satisifed that the nose has been de-bugged. then polish and re-wax.
yeah i always use stoners bug and tar remover just spray it on let it sit for a minute and wipe or light scrub off. The kicker is it will remove your fresh wax and leave you with a slight bit of residue look meaning your prob going to want to do this before a car wash. We also have goo gone as a household product here so if i run out of my stoners i have been known to use goo gone with similar results. In fact when i demolded my truck i used goo gone on the whole thing to remove tape residue.
Panty hose and bug & tar remover works great for the bug splatter.
windshild washer fluid and a window squeegee the sponge part it works wonders
1 - 20 of 24 Posts
