Only 3 wheels have sensors in them and of those only 2 work Tried the over inflate to wake up sensors that are sleeping apparently that doesn’t work on cars
I personally have no use for the system and would love to disable it totally Can that be done?
Thanks
Keith
You should be able to disable it with an advanced scan tool like AlfaOBD or Appcar's DiagFCA.
Ok here the follow up Alfaobd does turn it off and it does some really cool stuff other then that I have also found that it will supposedly program keys I have my pin but it says the security key is invalid which is funny because it works and it starts so it can’t be to invalid Alfaobd works well but it’s not cut and dry on everything you I’ll keep you posted on the key programming
