1 - 7 of 7 Posts
Hello Everyone!
New to the board.
I just replaced the 42rle in my son's 2006 300 Touring RWD with a used auto salvage tranny. (supposedly 90k)
When I went to test drive the car, reverse was slow to drop in, when I put it in to drive(D) it started to drop in and out. (Engaging disengaging) I put in neutral set the break and grabbed the scan tool. The codes are as follows:
P1713 Restricted manual value in T2 range
P0733 Gear ratio error in 3rd
P1790 Fault immediately after shift
I switched to (view data) to see what was happening, it appears the tranny is trying to find the gear, it's bouncing around to 2nd, 3rd, low.
I put it in to reverse it dropped right in, put into drive again it dropped right in, doing this a few times I noticed sometimes it dropped into low, and sometimes it dropped into 2nd. It works better after everything is warm, but once it cools down it starts over again. When it drops into gear, it is in gear and it drives as it should, (up shifts down shifts kick down to accelerate ect.
One other thing the scan says, trans temp very cold - true
cool - true
hot-false
Seems odd to me.
I'm really confused, I have no background info on the tranny, it came drained, I put on a new filter and added 8 quarts of ATF+4. Any help would be greatly appreciated!
Kind of long winded but I wanted to try to cover everything.
Thank you for your time!
This makes it sound like lip seals. When they go bad, it takes a while to build up pressure. But once the trans is "pumped up", it usually will be fine. They used to call this "morning sickness", because owners would say, "It only does it first thing in the morning, when it's cold".
But some of the other issues, like hunting for the correct gear and so on, make it sound like you might have more than one issue, like a bad conductor plate.
I wouldn't bother messing around with a 42RLE in this condition. They're stacked up like cordwood in most boneyards. I'd just look for one that's still in the car, so you can verify the mileage, check the trans fluid, and generally look the car over to get an idea of how it was maintained.
Good luck!
Good luck!
Thank you for the quick reply!
Have you talked to the salvage yard who sold it to you? Usually they give some kind of warranty.
Hello Everyone!
New to the board.
cool - true
hot-false
Seems odd to me.
Just a curiosity, did you stick with the 42RLE or upgrade to the Mercedes 5 speed? Having more experience than I care to admit with intrepid's, it was never the greatest transmission in it's original FWD form, I was aghast when I heard they had converted it to rear and were pairing it with a demasculated 2.7L for the base 300 and Charger. The 2.7 was already the worst thing Chrysler ever put in a car during it's LH run. I bought 7 Intrepid SE's between 88K and 115K miles all with grenaded engines, swapped them for wrecking yard 3.2 and 3.5L, never heard one run before it was installed and yet never got a dud. In 04 the 2.7 put out an anemic 200hp, so for 05 Chrysler derates it to 190hp and pairs it with the already suspect 42LE converted to rear drive and puts the combo in a heavier car. I maintain to this day the only reason they did this was to make the base car performance so pathetic that people would spend the extra money for a touring or limited. Having driven one back then it was painfully obvious how this combination spoiled everything that made the lx a great car other than when it was parked.
1 - 7 of 7 Posts
