I can hear it when it's set to over 20, but it seems to go back to 5 or 6 and I have to increase it every time I start Guidance. Is there a way to keep it set at a certain level or should it be staying at the level I selected all by itself?
Discussion Starter #2
Below is what I found in the manual: Seems to be working like it should but I only tried it once.
Nav Guidance Volume
Press the “+” or “–” buttons on the touchscreen to adjust the Nav Voice Prompt Volume.
NOTE: If the NAV Volume Adjustment setting is set between level 0 and 11 it will default to level 12 on a vehicle restart, if the NAV Volume Adjustment setting is set between level 13 and 38 it will RETAIN the setting on a vehicle restart.
