water pump noise
Discussion in 'Chrysler 300 General Discussion' started by dboyw, Dec 3, 2017.
  1. dboyw
    dboyw New Member
    Sep 13, 2015
    1
    0
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2008
    Trim?:
    300C
    Color?:
    Brilliant Black
    A few weeks ago I discovered a coolant leak (was the thermostat gasket). Since the car has over 100,000 on it I decided to replace upper and lower hoses, thermostat, and water pump. Everything from Pepboys. All went well except for installing the idler pulley. I had to grind down some casting marks for the pulley to free spin.
    Now the car has a "rattling noise to it. I removed the belt today thinking I did not grind down enough on the idler pulley. That was fine. Hand spun the water pump and it has a squeaking noise to it. Sounds like slipping on rubber. Started car for a few second to see if noise still there without belt. No noise. Sprayed WD-40 on water pump shaft and no change to noise. Reinstalled everything and noise is still there.
    Am ideas? Bad water pump?
  2. Chris.84
    Chris.84 New Member
    Nov 26, 2017
    5
    0
    Gender:
    Male
    Augusta, ga
    Vehicle:
    300
    Vehicle Yr:
    Gen1 - 2008
    Trim?:
    Touring
    Color?:
    Linen Gold
    Sounds like you just have a bad water pump, take it off and pep boys should exchange no problems
Share This Page
