Hi, I'm stumped on what's causing my power steering whine.
I changed the high pressure line from the pump to rack, new pump, feed line to pump, and put in a new resevoir.
I swapped out 32oz of fluid with Valvoline ATF+4.
At idle it sounds like a meat saw. clip of car running.
Any ideas on what to do next?
Discussion Starter #2
The loud whine in the video is separate from the power steering whine. The noise sounds like it's coming from the driver's side.
Also I think it's not charging all the way. Attached 2 pictures of voltage reading at different rpms.
Idler, tensioner, water pump, and power steering pulleys were replaced.
Are you sure it's the power steering, the sound wasn't terribly clear on your video, but I would bet dollars to donuts it is the alternator crapping out. Mine just did last week, I was chasing a whining noise around for days, sounded like motor static on an AM radio, finally figured it out when the battery light illuminated on the second day, I swore the sound was coming from the drivers side, but the way the alternator is bolted to the front cover the sound resonates.
21339
Because I am a cheap bastard I went to the U pull it yard and got an 805AD off of a 2010, $30. Didn't realize they had changed the plug in 08 so had to go back for one, but used my drill and wire wheel to remove all of the patina then put a clear coat on it. Works great and saved $120, just changed the power steering fluid tonight.
[/QUOTE]
Are you sure it's the power steering, the sound wasn't terribly clear on your video, but I would bet dollars to donuts it is the alternator crapping out. Mine just did last week, I was chasing a whining noise around for days, sounded like motor static on an AM radio, finally figured it out when the battery light illuminated on the second day, I swore the sound was coming from the drivers side, but the way the alternator is bolted to the front cover the sound resonates. View attachment 21339
[/QUOTE]
Actually, I didn't realize it at first but there are 2 whining noises that you can hear. The power steering has a low whine but the supercharger noise only happens when it's warm.
Also my radio stopped working. Fog lights never did. From what I read these cars start having electrical gremlins when the voltage isn't perfect.
I found a TSB for oil squirters that explains that loud whining. I'll upload a video of it running cold. Either way I'm still replacing the alternator and the rest of the power steering lines. If it's not oil squirters, I hope it's the alternator. I'll update when I throw more parts at it.
13.6 volt is the bare minimum for an alternator, it might be a sign it's going bad. Look up google for ways to test it.
